During the four and a half months I occupied Advance Base alone, I kept a fairly complete diary. Nearly every night, before turning in, I sat down and wrote a thoroughgoing account of the day's doings. Yet, I have been surprised and puzzled, on reading the entries four years later to find that not more of the emotions and circumstances which I have always associated with the first few days alone were actually committed to paper. For afterwards, it seemed that I was never busier. Although I was up mornings before 8 o'clock and rarely went to bed before midnight, the days weren't half long enough for me to accomplish the things I set out to do. A fagged mind in the midst of a task had little patience with autobiographical trifles. As witness:
March 29
. . . Last night, when I finished writing, I noticed a dark patch spreading over the floor from under the stove. A bad leak had opened up the fuel line. Worried about the fire risk, I shut off the stove and searched all through my gear for a spare line. I couldn't find one, which annoyed me; but I finally succeeded in stopping the leak with adhesive tape borrowed from the medical chest. Result: I was up until 4 o'clock this morning, most of the time damned cold, what with the fire out and the temperature at 58 degrees below zero. The cold metal stripped the flesh from three fingers of one hand. (Later) This being the twenty-second anniversary of the death of Captain Robert Falcon Scott, I have been reading again his immortal diary. He died on this same Barrier, at approximately the same latitude as that of Advance Base. I admire him as I admire few other men; better than most, perhaps, I can appreciate what he went through . . .
March 30
There will be no peace until I know that the tractor party has reached Little America safely. I blame myself for having kept them here so long. Well, the radio schedule two days hence will tell the story. I've been principally occupied with putting the tunnels to rights, and not succeeding very well on account of my shoulder, which maddens me not so much from pain as from its uselessness. A fearful amount of lifting remains to be done. So far, I've managed with one hand by using my hip as a fulcrum. . . .
March 31
. . . It's been a deuce of a job to wake up without an alarm clock. And this is puzzling, because I've always been able to fix my mind the time at which I should awaken, and wake up at that time, almost to the minute. I was born with that gift, and it has stood me in good stead when I dash around the country on lecture tours, leaping from hotels to trains on split-second schedules. But now the gift has simply vanished, perhaps because I am putting too much pressure on it. At night, in the sleeping bag, I whisper to myself: Seven-thirty. Seven-thirty. That's the time you must get up. Seven-thirty. But I've been missing it cleanly -- yesterday by nearly an hour, and this morning by half an hour.
I was not long in discovering one thing: that, if anything was eventually to regularize the rhythm by which I should live at Advance Base, it would not be the weather so much as the weather instruments themselves. I had eight in continuous operation. One was the register, already described, which kept a continuous record of wind velocities and directions. The electrical circuit, connecting with the weather vane and wind cups on the anemometer pole topside, was powered by nine dry cell batteries; and the brass drum with the recording sheet was turned by a clock-work mechanism which I had to wind daily. The sheet was lined at intervals corresponding to five minutes in time; and between these lines two pens, one representing the speed of the wind and the other its direction, wrote steadily from noon of one day to noon of the next.
Two other instruments were thermographs, which recorded temperature changes. The so-called inside thermograph was a fairly new invention, whose unique virtue was that it could be housed inside the shack. A metal tube filled with alcohol projected through the roof, and the expansions and contractions of the liquid in the tube drove a pen up and down over a rotating sheet set in a clock-faced dial hanging from the wall, just over the emergency radio set. The sheet, marked with twenty-four spokes for the hours and with concentric circles for the degrees of temperature, made one rotation in twenty-four hours; it would record accurately down to 85 degrees below zero. The outside thermograph was a compact little mechanism which served the same function, except that it stood in the instrument shelter topside and the sheets needed changing only once a week.
Besides these instruments, I had a barograph to record atmospheric pressure, which was kept in a leather case in the food tunnel. Plus a hygrometer employing a human hair, for measuring humidity (not very reliable, though, at cold temperatures). Plus a minimum thermometer, which measured the lowest temperature. In it was a tiny pin which was dropped by the contraction of alcohol in the column. Alcohol was used instead of mercury because mercury freezes at -38 degrees whereas, pure grain alcohol will still flow at -179 degrees. This instrument was useful as a check on the thermographs. It was kept in the instrument shelter, a boxlike structure set on four legs, which stood shoulder high, close to the hatch. The sides were overlapping slats spaced an inch apart to allow air to circulate freely and yet keep out drift.
If I had had any illusions as to being master in my own house, they were soon dispelled. The instruments were masters, not I; and the fact that I knew none too much about them only intensified my humility. There was scarcely an hour in the living day of which a part was not devoted to them or observations connected with them.
Every morning at 8 o'clock sharp -- and again at 8 o'clock in the evening -- I had to climb topside and note the minimum temperature reading, after which I would shake the thermometer hard to put the pin back into the fluid. Then, standing five minutes or so at the hatch, I would consult the sky, the horizon, and the Barrier, noting on a piece of scratch paper the percentage of cloudiness, the mistiness or clarity, the amount of drift, the direction and speed of the wind (a visual check on the register), and anything particularly interesting about the weather. All of these data were dutifully entered on Form No. 1083, U.S. Weather Bureau.
Every day, between 12 o'clock and 1 o'clock, I changed the recording sheets on the register and the inside thermograph. The pens and the pads supplying them always needed inking, and the thermograph clock had to be wound. Mondays I performed the same service for the outside thermograph and the barograph.
April came in on Easter Sunday. It came in blowing and snowing, bringing a southeaster which laced the air with drift but shot the temperature up from -48 degrees to -25 degrees before the day was done. Not a pleasant day, but decidedly on the warmish side, after March's cold. In the morning at 10 o'clock, I attempted the first radio contact with Little America. Considering my inexperience, the fact that it was successful -- at least in that I managed to make myself understood -- set me up enormously. For, if any contingency truly disturbed me, it was the chance of my losing radio contact with Little America. Not on my account, but on the expedition's account generally. In spite of the orders I had given and the promises made to respect them, I knew in my own heart that both might be ignored if Little America was out of touch with me for long. And, if Little America chose to act, an appalling tragedy might easily result. Realizing how much depended upon my ability to hold communication, I was oppressed by the thought I might fail through sheer ignorance. Dyer had shown me how to make repairs, and Waite had coached me in operating the set; but, whenever I looked at the complications of tubes, switches, and coils, my heart misgave me. I scarcely knew the Morse code. Fortunately Little America could talk to me by radio telephone. So I wasn't obliged to decipher hot outpourings of dots and dashes from skillful operators. But reply I must in dots and dashes, and that I doubted I could do.
Two hours before the schedule I made ready. The gasoline-driven generator which powered the transmitter stood in an alcove, about halfway down the food tunnel, from which a six-inch ventilator pipe went through to the surface. Of course, it couldn't be run in the shack on account of the fumes. To drive the chill out of the metal I brought the engine indoors and put it on the chair, close to the stove. There the engine stood for an hour and a half, dripping with moisture. Then I filled the tank with a mixture of gasoline and lubricating oil, hurried the engine back to the alcove and tried to start it before the metal chilled. I cranked it after the fashion of an outboard motor, using a cord with a wooden handle at one end and a knot at the other. The knot slipped into a notch in the small flywheel; and, after taking a couple of turns around the wheel, I'd pull hard, spinning the engine. That morning it started off on the first spin. By then it was nearly 10 o'clock, and I had to leg it back into the hut to meet the schedule on time.
The receiver was tuned for 100 meters. The tubes glowed when I threw the switch, and the dial readings showed that everything was as it should be. I waited five minutes or so for the tubes to warm up. Precisely at 10 o'clock, as I clamped on the headphones, I heard Dyer's clear, modulated voice saying: "KFZ calling KFY. This is KFZ calling KFY. Will you please come in?" Excited, as nervous as a student pilot on his first solo hop, I cut in the transmitter and keyed: "OK, KFZ. All well. How are trail parties?" Or at least that was what I tried to spell out. The dot-dash equivalents were as confusing and unfamiliar as Arabic, and in the middle of a sentence I forgot completely what I was supposed to be sending.
Nevertheless, Charles Murphy came on a moment later with the news that both the Advance Base crew and Innes-Taylor's party were safely at Little America. "All hands are well," he continued. After a few more remarks I heard him say, "Is everything all right with you?"
I was encouraged to make a more elaborate answer. "Great, working hard. Wind here thirty miles. Snowing. Think blow coming."
Murphy chuckled, "I think John got most of that. No snow here as yet, but an easterly is making with lots of drift."
The contact lasted only twenty minutes. The schedule days were confirmed: Sundays, Tuesdays, and Thursdays, at 10 o'clock, with daily emergency schedules to take effect at the same hour whenever my regular schedule was missed. Just before we signed off, Charlie said, "Dyer rates you D minus on your debut, but I think you deserve better than that."
To this I retorted, "Yes, world's finest radio operator south of Lat. 80 degrees."
That night I wrote in my diary: ". . . The fact that the tractor party and Innes-Taylor's party are safely at Little America has raised my spirits to a new high. This is wonderful news. For the first time, after the months of struggle and anxiety, Little America is at last buttoned up for the winter, and so am I. If we both obey our common sense, nothing untoward need happen. I am free to take stock of my own situation and to make the most of the experience that is to be mine. I realize at this moment more than ever before how much I have been wanting something like this. I must confess feeling a tremendous exhilaration."
Now I could relax temporarily and suffer the blow to come on. Monday the 2nd, the wind blew some more, after backing into the east. Tuesday it hiked into the north and blew a little harder. The bottom dropped out of the barometer. Utterly fascinated, I followed the purple trace as it sank on the barograph. In the space of sixteen hours the pressure dropped two-thirds of an inch. About 5:30 o'clock in the afternoon the trace ran right off the bottom of the sheet. The outside barometer finally fell to 27.82 inches. At home a reading of that order would have presaged a hurricane more violent than the great Florida blow. All the portents of an earth-rending uproar were in the air. The wind rasped on the roof. The clacking of the anemometer cups settled into a hum. Drift sifted down through the intake ventilator, making a cold heap on the floor. When I went topside for the last observation, I could scarcely lift the trapdoor against the wind's push; and the drift funneled down the hole with force enough to take the breath away.
But the barometric portent, as so often it is in high latitudes, was a mumbling lie. Consulting the wind record next morning, I found that the velocity had not risen over thirty-five miles per hour during the night. Wednesday the 4th was still windy, but the barometer rose again. That day I found the roof of the fuel tunnel caving under the accumulating weight of drift. The roofing canvas was bulging between the supporting planks, and two planks had already given way. Fearful that the whole tunnel might cave in and that, with my crippled arm, I should never be able to dig it out before the next blizzard, I shored it up as best I could with boxes and two-by-four timbers. The cold following the quieting of the gale would in time anneal the new, light snowflakes into a hard bridge over the tunnel; but to hasten the process I spent hours melting snow on the stove, carrying the water topside, and pouring it over the weak spots. The temperature was 6 degrees above zero, which should have seemed positively warm, compared to the -60 degrees weather I had become acclimatized to in March. The wind, however, cut to the bone; and my nose and cheeks were raw from frostbite. I went without hot food, preferring to use the stove continuously for melting snow; that night I slipped into the bunk an exhausted man.
April 5
This morning, when I awakened, I could tell by the sound that the wind had dropped, though drift was still sifting through the outlet ventilator and past the stovepipe. I dressed rapidly and hurried up the ladder to take the 8 a.m. "ob." But, when I heaved with my good shoulder against the trapdoor, it refused to give. Half-asleep and stiff with cold, I continued to push as hard as I could. Still the panel would not budge. Remembering then the thick, double-action feature, I yanked out the restraining pegs and tried pulling down. This didn't work, either. Even when I kicked loose from the ladder and swung out, clinging to the handle with my left hand, the door did not stir. This was serious. I let go and dropped in a heap to the veranda floor, and the thought broke through my numbed senses: You're caught now. You're really caught, double-action and all.
With the flashlight, which I usually carried suspended from a cord looped around my neck, I located a long two-by-four under a jumble of gear in the veranda. Using my good arm to drive and the other to balance, I manipulated the timber as a vertical battering ram. Fifteen or twenty minutes of hard pounding served to crack the door a little; and, by bracing myself on the ladder and throwing the strength of my back against the panel, I finally succeeded in wedging an opening wide enough to wiggle through. Once on the surface, I quickly found the cause of the trouble. The day before, while I was working in the food tunnel, the shack door had been open a long time. The warm air had evidently softened the snow around the hatch; and, after the warmth was cut off, this melted margin had solidified into hard ice, which had wedged the door shut.
However, ice was not alone to blame. A full two and a half feet of drift lay packed over the trapdoor. This accumulation, I noticed, had built up behind the ventilator pipe and instrument shelter, which, in an easterly gale, stood to windward with respect to the trapdoor. Moreover, I observed further that the shack's not having been sunk quite enough was causing a thick shell of hard snow to come over the roof. Since the trapdoor was on the west side of the shack, it had naturally caught the brunt of the drift, which always fans out to leeward of any upraised object in the pattern of a ship's wake.
All that day, when not otherwise occupied with my observations, I hacked and dug and sawed at the offending mound, endeavoring to level off the surface round the shack. The day came off fine, but the spent wind still tossed up clouds of drift, and I did not want to go through another experience like yesterday's. The failure of my pet door had impressed me with the necessity of having an alternative hatch, against similar emergencies. Indeed, I had already planned such a one, had, in fact, worked on it intermittently during the blizzard.
My idea was to breach a hole in the west-pointing food tunnel and mine at right angles to it a new south-pointing passageway. The direction was selected after careful study. From experience with Antarctic weather I knew that the prevailing winds are easterly; the easterlies are the strong, snow-making, drift-making winds. Since I was powerless to prevent the drift from building up in the lee of the stovepipe and ventilator pipes, instrument shelter, and the shack itself, and therefore, over the food and fuel tunnels, the logical move was to drive a third tunnel out of the drift zone. Even this would not give complete security as a norther or a souther might come along presently and build up new drift ridges at right angles to those already cast up. Queerly, there is little actual increment from snowfall. Most of it blows away; yet, if the Empire State Building were standing in the Antarctic, it would eventually be smothered in drift.
I started the tunnel about midway down the food tunnel, directly opposite the recess in which the radio engine sat. It was to be from thirty to thirty-five feet long, about six feet high, and four feet wide. I proposed to carry it two or three feet below the surface, and, at the far end, to hole out a little shaft which would come within a foot of the surface. This thin shell could then be punctured whenever the other exit was blocked off. However, a foot a day, I decided, would be all I could do. "Even a foot means hard work," my diary observes, "because I can use only my left arm. I saw the blocks out, then carry them to the hatch, where I hoist them to the surface, load them aboard a small man-hauling sledge, and haul them some distance to leeward."
Unless you know something about the character of Antarctic snow, the reference to sawing it out in blocks may be puzzling. Except that it has been fused by cold, rather than heat, the Barrier snow is like a kind of sandstone. It is hard and brittle. You can't make snowballs with it. When you rub it, tiny icelike globules shred off. The color is the whitest white you ever saw; it has none of the smoothness and transparency of ice. After cold has coalesced the crystals of newly fallen snow, you can walk over it and not leave an impress. At times skis will slide helplessly as on slick glacier ice. You can't shovel that kind of snow. A shovel rings when it strikes as it might against rock. I used a two-foot hand saw. With this I cut out blocks, which could be pried clear with a shovel, leaving nice straight lines and debris easy to handle.
As a matter of fact, the escape tunnel was no wasted effort against a distant contingency. It became my water supply. All I had to do was to saw the blocks to a size suitable for the water bucket, and stack them in the veranda like cordwood. Yet, melting snow was an unmitigated nuisance; I loathed it. Two gallons of snow wielded barely two quarts of water after several hours on the stove. The water bucket was almost never off the stove; and, while it was there, little room was available for anything else. I came to hate its soot-blackened, dented sides; its greedy, ever-gaping maw; and once, when it careened to the floor and spilled all the water accumulated for supper, I cheerfully booted the bucket across the shack. Stooping to retrieve it, I caught my reflection in the shaving mirror. I was actually grinning.
April 6
I am sleeping fairly well, which is a blessing. But I still can't seem to wake up when I want to -- missed by three quarters of an hour this morning -- which is a nuisance. I don't know why I've lost the faculty; I'll have to regain it somehow. When the long night comes, I shall have no light to awaken me. I'm keeping the skylights cleared of snow to enjoy what little daylight remains. But all three are frosted over most of the time. When the temperature at the ceiling passes freezing, the frost melts; and the drip-drip-drip makes little ice stalagmites on the floor, which is always cold. I've proved, with a thermometer, that when I'm sitting down the temperature at the level of my feet is anywhere from 10 degrees to 30 degrees colder than at my head . . .
April 7
The six months' day is slowly dying, and the darkness is descending very gently. Even at midday the sun is only several times its diameter above the horizon. It is cold and dull. At its brightest it scarcely gives light enough to throw a shadow. A funeral gloom hangs in the twilight sky. This is the period between life and death. This is the way the world will look to the last man when it dies.
April 8
Were it not for my lame shoulder and the difficulties caused by the weather instruments (which were designed for a warmer place), I should be making much better progress in preparing myself for the oncoming darkness. Unpredictable things, small but often annoying, make continuous demands upon my time. For example, I find that even when there is no drift, the three-and-one-half inch outlet ventilator fills every three or four days with ice (or rather with what looks like neve, which is between snow and ice). It's due, I think, to condensation. Anyhow, I've got to watch that. Good ventilation I must have at any cost. The pipe being held in place by friction, I just pull it out of the hole, carry it below, and lay it on the stove to thaw. The icy stuff won't pound out. It has to be melted.
Just to complicate matters, the same trouble is developing in the topside end of the stovepipe. Around dinner time (or whenever the stove is running hot) the ice melts, and the water runs through a hole in the elbow. Luckily, the register, which stands directly underneath, has a glass top; otherwise it would have been out of commission long ago. I have tied a can under the elbow to catch the water. Nevertheless, I'm rather worried about the blockage in the pipe; unless the fumes from the stove escape to the surface. I shall have trouble. . . .
Thus the first part of April hurried like a man on an errand. I was occupied with all kinds of small projects. Aside from the Escape Tunnel, the hardest task was putting the food and fuel tunnels to rights. These two parallel corridors, it will be remembered, ran out from the veranda and were separated by a three-foot wall of snow. Both were dark as dungeons; whenever I worked in them it was by the light of a storm lantern or flashlight. In the artificial light, though, they acquired a breathless radiance. The ice crystals, which were thickening on the canvas roofing, glistened like candelabra; and the walls glowed with a sharp, blue nakedness.
In the fuel tunnel were four fifty-gallon kerosene drums, weighing about five hundred pounds each, which we set in individual recesses. Besides this, I had 360 gallons of Stoddard solvent for the stove, which came in handy twelve-gallon drums weighing about ninety pounds each. In addition I had about ninety gallons of gasoline for the radio generator, in two large drums at the far end of the tunnel. Except for the fact that the drums all stood upright so as to prevent leakage from the bungs, the place used to remind me sometimes of a French wine cellar, especially the shadows cast by my figure as I moved about in front of the lantern.
The food tunnel, which opened directly in front of the door, was a different sort of place. There the walls were formed by the boxes of foodstuffs themselves. Wanting something, I simply had to pry open the sides with a chisel and take out whatever I needed, leaving the empty box as a permanent wall. What disturbed me was the haphazard manner in which the boxes had been stowed. Here and there the walls were bulging out; the beans were hopelessly mixed with the canned meats, tomato juice, and boxes of odds and ends; and the roof was caving in. All this offended my growing sense of neatness. During my spare time I set about rearranging the whole setup.
I didn't try to rush the job. If the polar regions have taught me anything, it is patience. I rarely spent more than an hour on any one job, preferring to shift to something else. In that way I was able to show a little progress each day on all the important jobs, and at the same time keep from becoming bored with any one. This was a way of bringing variety into an existence which would be basically monotonous.
Not that the materials for variety were ever lacking to a mind capable of forgetting what civilization was like. The sheer rigorousness of the Barrier took care of that. At times I felt as if I were the last survivor of an Ice Age, striving to hold on with the flimsy tools bequeathed by an easy-going, temperate world. Cold does queer things. At 50 degrees below zero a flashlight dies out in your hand. At -55 degrees kerosene will freeze, and the flame will dry up on the wick. At -60 degrees rubber turns brittle. One day, I remember, the antenna wire snapped in my hands when I tried to bend it to make a new connection. Below -60 degrees cold will find the last microscopic touch of oil in an instrument and stop it dead. If there is the slightest breeze, you can hear your breath freeze as it floats away, making a sound like that of Chinese firecrackers. As does the morning dew, rime coats every exposed object. And if you work too hard and breathe too deeply, your lungs will sometimes feel as if they were on fire.
Cold -- even April's relatively moderate cold -- gave me plenty to think about. The novocaine in my medical kit froze and shattered the glass tubes. So did the chemicals in the fire bombs. Two cases of tomato juice shattered their bottles. Whenever I brought canned food inside the shack I had to let it stand all day near the stove to thaw. On very cold days the kerosene and Stoddard solvent flowed like cylinder oil; I dug a deep hole in the tunnel floor for my can to lengthen the drop in the rubber hose which I used as a syphon. Frost was forever collecting on the electrical contact points of the wind vane and wind cups. Some days I climbed the twelve-foot anemometer pole two and three times to clean them. It was a bitter job, especially on blustery nights. With my legs twined around the slender pole, my arms flung over the cleats, and my free hands trying to scrape the contact point clean with a knife and at the same time hold a flashlight to see, I qualified for the world's coldest flagpole sitter. I seldom came down from that pole without a frozen finger, toe, nose, or cheek.
The shack was always freezingly cold in the morning. I slept with the door open. When I arose the inside temperature (depending upon the surface weather) might be anywhere from 10 degrees to 40 degrees below zero. Frost coated the sleeping bag where my breath had condensed during the night; my socks and boots, when I picked them up, were so stiff with frozen sweat that I first had to work them between my hands. A pair of silk gloves hung from a nail over the bunk, where I could grab them the first thing. Yet, even with their protection, my fingers would sting and burn from the touch of the lamp and stove as I lighted them. The old flesh had sloughed off the tips, and the new flesh for a while was insufferably tender. So I had my troubles. Some came from my own inadequacies. At first I had a devil of a time with the weather instruments. The traces became horribly blotched, the pens stuck, and the instruments themselves stopped without rhyme or reason. But, one way or another, I usually managed to contrive a cure. I learned how to thin the ink with glycerine to keep it from freezing, and how to cut the oil in the instruments with gasoline and rub the delicate parts with graphite which wasn't affected so much by the cold.
Yet, in playing Admirable Crichton to myself, I was far from distinguished. Many of my Advance Base concoctions wouldn't have passed Captain's Inspection. In the Navy phrase, they were generally no better than "lash-up." As to that, I plead nolo contendere and throw myself on the court's mercy. An officer, I was learning to do things again with my hands. My standards were humble. If anything, I was again a worshipping disciple of the God of 2.5 of Naval Academy days, the god of the hairsbreadth passing grade, as personified by Tecumseh, at whose bust we midshipmen used to chip penny offerings as we marched to examinations. By Academy standards, I should have "bilged out" of Advance Base on cooking alone.
Breakfast didn't count. I rarely took more than tea and a whole-wheat biscuit. Lunch was habitually an out-of-the-can affair, consisting usually of tomato juice, Eskimo biscuits, and frequently a cold meat or fish -- either corned beef, tongue, or sardines. These I prepared in masterly fashion. But supper, by rights the high spot in an explorer's day, the hot meal toward which a cold and hungry man looks with mounting anticipation -- this meal for a while was a daily fiasco.
I have only to close my eyes to witness again the succession of culinary disasters. Consider what my diary designated as The Corn Meal Incident. Into a boiler I dumped what seemed a moderate quantity of meal, added a little water, and stood it on the stove to boil. That simple formula gave birth to a Hydra-headed monster. The stuff began to swell and dry up, swell and dry up, with fearful blowing and sucking noises. All innocently I added water, more water, and still more water. Whereupon the boiler erupted like Vesuvius. All the pots and pans within reach couldn't begin to contain the corn meal that overflowed. It oozed over the stove. It spattered the ceiling. It covered me from head to foot. If I hadn't acted resolutely, I might have been drowned in corn meal. Seizing the container in my mittened hands, I rushed it to the door and hurled it far into the food tunnel. There it continued to give off deadly golden lava until the cold finally stilled the crater.
There were other disasters of the same order. There was the Dried Lima Beans Incident of April 10th. ("It's amazing," the diary reports soberly, "how much water lima beans can absorb, and how long it takes them to cook. At supper time I had enough half-cooked lima beans to feed a ship's company.") My first jelly dessert bounced like a rubber ball under my knife; the flapjacks had to be scraped from the pan with a chisel. ("And you, the man who sat at a thousand banquets," goes the accusing entry of April 12th.) I dreaded banquets before I went to Advance Base; and I have come to dread them since. But in April's dark hours I ransacked my memory, trying to remember what they were like. All that I could recall was filet mignon spiced and darkened to the color of an old cavalry boot; or lobster thermidor; or squabs perched on triangles of toast; or chicken salad heaped on billowing lettuce. All these were far beyond the simple foods in my larder. When I did experiment, the results filled the shack with pungent burning smells and coated the skillets with awful gummy residues. But, in spite of the missing cook book, the record was not one of unmitigated failure. Resolved to make a last stand, I took the surviving chicken, hung it for two days from a nail over the stove to thaw, boiled it all one day, seasoned it with salt and pepper, and served. The soup, which was an unexpected by-product, was delicious; that night I broached a bottle of cider and drank a toast to Escoffier.
Thus April moved along. Each night, as the last formal act of the day, I crossed off another date on the big calendar on the wall, and each morning consulted the calendar the first thing, to make sure that I hadn't forgotten. Above me the day was dying; the night was rising in its place. Ever since late in February, when the sun had rolled down from its lofty twenty-four-hour circuit around the sky, it had been setting a little earlier at night, rising a little later in the morning. Now, with less than a fortnight of daylight left in this latitude, it was just a monstrous ball which could barely hoist itself free from the horizon. It would wheel along for a few hours, obscured by mist, then sink out of sight in the north not long after noon. I found myself watching it as one might watch a departing lover.
April 9
. . . I have just seen (at 9 p.m.) a curious phenomenon. At first it appeared to be a ball of fire, which was smaller and redder than the sun. It bore about 205 degrees true. I couldn't identify it. Going below, I got the field glasses and kept watching it. It changed from deep red to silver, and every now and then blanked out. It was astonishing how big it looked at first. But after long study I finally figured out that it consisted of four brilliant stars, very close together in a vertical line. However, they may not have been four stars but one having three images of itself refracted by ice crystals . . .
April 12
. . . It has been crystal clear, with a temperature of about 50 degrees below zero, and a whispering southerly wind that set fire to the skin. Each day more light drains from the sky. The storm-blue bulge of darkness pushing out from the South Pole is now nearly overhead at noon. The sun rose this morning at about 9:30 o'clock, but never really left the horizon. Huge and red and solemn, it rolled like a wheel along the Barrier edge for about two and a half hours, when the sunrise met the sunset at noon. For another two and a half hours it rolled along the horizon, gradually sinking past it until nothing was left but a blood-red incandescence. The whole effect was something like that witnessed during an eclipse. An unearthly twilight spread over the Barrier, lit by flames thrown up as from a vast pit, and the snow flamed with liquid color.
At home I am used to seeing the sun leap straight out of the east, cross the sky overhead, and set in a line perpendicular to the western horizon. Here the sun swings to a different law. It lives by extremes. In the spring it rises for the first time at noon and for the last time at midnight. As in the fall, it rises and sets daily for a month and a half. Then for four months and a half it never sets at all, never crosses directly overhead, but instead wheels around the horizon, nearly parallel to it and never rising higher than 33-1/2 degrees. In the fall it sets for the first time at midnight, and sets for good at noon. Then for four and a half months it does not rise at all, but instead sinks gradually below the horizon to a depth of 13-1/2 degrees before it begins to lift again. This is the period I am approaching now; a period when the day seems to be holding its breath.
Thus the coming of the polar night is not the spectacular rush that some imagine it to be. The day is not abruptly walled off; the night does not drop suddenly. Rather, the effect is a gradual accumulation, like that of an infinitely prolonged tide. Each day the darkness, which is the tide, washes in a little farther and stays a little longer; each time the day, which is a beach, contracts a little more, until at last it is covered. The onlooker is not conscious of haste. On the contrary, he is sensible of something of incalculable importance being accomplished with timeless patience. The going of the day is a gradual process, modulated by the intervention of twilight. You look up, and it is gone. But not completely. Long after the horizon has interposed itself, the sun continues to cast up a pale and dwindling imitation of the day. You can trace its progress by the glow thrown up as it makes its round just below the horizon.
These are the best times, the times when neglected senses expand to an exquisite sensitivity. You stand on the Barrier, and simply look and listen and feel. The morning may be compounded of an unfathomable, tantalizing fog in which you stumble over sastrugi you can't see, and detour past obstructions that don't exist, and take your bearings from tiny bamboo markers that loom as big as telephone poles and hang suspended in space. On such a day, I could swear that the instrument shelter was as big as an ocean liner. On one such day I saw the blank northeastern sky become filled with the most magnificent Barrier coast I have ever seen, true in every line and faced with cliffs several thousand feet tall. A mirage, of course. Yet a man who had never seen such things would have taken oath that it was real. The afternoon may be so clear that you dare not make a sound, lest it fall in pieces. And on such a day I have seen the sky shatter like a broken goblet, and dissolve into iridescent tipsy fragments -- ice crystals falling across the face of the sun. And once in the golden downpour a slender column of platinum leaped up from the horizon, clean through the sun's core; a second luminous shadow formed horizontally through the sun, making a perfect cross. Presently two miniature suns, green and yellow in color, flipped simultaneously to the ends of each arm. These are parhelia, the most dramatic of all refraction phenomena; nothing is lovelier.
April 14
. . . Took my daily walk at 4 p.m. today, in 89 degrees of frost. The sun had dropped below the horizon, and a blue -- of a richness I've never seen anywhere else -- flooded in, extinguishing all but the dying embers of the sunset.
Due west, halfway to the zenith, Venus was an unblinking diamond; and opposite her, in the eastern sky, was a brilliant twinkling star set off exquisitely, as was Venus, in the sea of blue. In the northeast a silver-green-serpentine aurora pulsed and quivered gently. In places the Barrier's whiteness had the appearance of dull platinum. It was all delicate and illusive. The colors were subdued and not numerous; the jewels few; the setting simple. But the way these things went together showed a master's touch.
I paused to listen to the silence. My breath, crystallized as it passed my cheeks, drifted on a breeze gentler than a whisper. The wind vane pointed toward the South Pole. Presently the wind cups ceased their gentle turning as the cold killed the breeze. My frozen breath hung like a cloud overhead.
The day was dying, the night being born -- but with great peace. Here were the imponderable processes and forces of the cosmos, harmonious and soundless. Harmony, that was it! That was what came out of the silence -- a gentle rhythm, the strain of a perfect chord, the music of the spheres, perhaps.
It was enough to catch that rhythm, momentarily to be myself a part of it. In that instant I could feel no doubt of man's oneness with the universe. The conviction came that the rhythm was too orderly, too harmonious, too perfect to be a product of blind chance -- that, therefore, there must be purpose in the whole and that man was part of that whole and not an accidental offshoot. It was a feeling that transcended reason; that went to the heart of man's despair and found it groundless. The universe was a cosmos, not a chaos; man was rightfully a part of that cosmos as were the day and night.
